MIT Engineers Print Synthetic ‘Metamaterials’ That Are Strong, Stretchy
New method could use ceramics, glass, and metals for tear-proof textiles or stretchy semiconductors
 Courtesy of the researchers
Metamaterials are synthetic materials with microscopic structures that give the overall material exceptional properties.
Jennifer Chu
Tue, 06/03/2025 - 12:02
In metamaterials design, the name of the game has long been “stronger is better.”
Metamaterials are synthetic materials with microscopic structures that give the overall material exceptional properties. A huge focus has been in designing metamaterials that are stronger and stiffer than their conventional counterparts. But there’s a trade-off: The stiffer a material, the less flexible it is.
MIT engineers have now found a way to fabricate a metamaterial that is both strong and stretchy. The base material is typically highly rigid and brittle, but it is printed in precise, intricate patterns that form a structure both strong and flexible.
The key to the new material’s dual properties is a combination of stiff microscopic struts and a softer woven architecture. This microscopic “double network,” which is printed using a Plexiglas-like polymer, produced a material that could stretch more than four times its size without fully breaking. In comparison, the polymer in other forms has little to no stretch and shatters easily once cracked.
