Berkeley Lab Optical Innovation Could Calm the Jitters of High-Power Lasers
New system holds the key to unprecedented accuracy in beam control
Joe Chew
Jeroen van Tilborg
Wed, 09/15/2021 - 12:02
The Berkeley Lab Laser Accelerator (BELLA) Center at the Department of Energy’s Lawrence Berkeley National Laboratory (Berkeley Lab) has developed and tested an innovative optical system to precisely measure and control the position and pointing angle of high-power laser beams with unprecedented accuracy—without interrupting or disturbing the beams. The new system will help users throughout the sciences get the most out of high-power lasers.
The experimental validation effort was led by doctoral candidate Fumika Isono of Berkeley Lab and UC Berkeley. Her findings are described in a paper published recently by the Cambridge University Press journal, High Power Laser Science and Engineering.
“This is a tremendous advancement in measurement and control that will benefit high-power laser facilities worldwide,” says Cameron Geddes, director of Berkeley Lab’s Accelerator Technology and Applied Physics (ATAP) Division, of which the BELLA Center is a part.
