The Answer to Manufacturing’s Waste Problem is Hidden in Data
Reduce waste by improving efficiency, enabling predictive maintenance, and streamlining resource management
V R Vijay Anand
Wed, 03/09/2022 - 12:03
As the world moves toward a new, post-pandemic normal, industries must leverage digital transformation at an accelerated pace. This is already happening. According to IBM, 67 percent of manufacturers have accelerated digital projects since Covid-19.
Although improved operational efficiency is typically the reason for these changes, manufacturers should capitalize on the convergence of Industry 4.0 and environmental, social, and governance (ESG) goals to improve their sustainability credentials. Data hold the key to reducing manufacturing’s waste problem.
