Survey of the NOvA Detectors at Fermilab
Thu, 11/07/2013 - 17:57
The NOvA (NuMI off-axis νe appearance) experiment is looking to answer fundamental questions about neutrinos and the role they play in the universe. NOvA will use two detectors, a near detector located underground at Fermilab in Batavia, Illinois, and a far detector located 810 km from Fermilab near the United States-Canada border in Ash River, Minnesota.
The 14 kton far detector and the 0.3 kton near detector are composed of several cells of extruded PVC plastic in a cellular structure. This article discusses the survey of the NOvA detectors using a laser tracker and laser scanner.
NOvA  is a second-generation experiment on the NuMI (neutrino at main injector) beamline designed to search for oscillations of muon neutrinos to electron neutrinos (νμ → νe) by comparing electron neutrino rates at Fermilab with electron neutrino rates observed 810 km away from Fermilab at Ash River, Minnesota (figure 1).1
